Conforming clothing question
Is there a way to make a piece of clothing ignore certain morphs of the figure it is fit to? I swear I stumbled on a way to do it in the past, but can't seem to find it again..
My goal is to get rid of certain obtrusive morphs that cause pockets and overlap/clipping in the clothing so I can use dForce to get a more realistic result.
Cheers.
  • LeanaLeana Posts: 13,644
    You can either set the "autofollow" parameter on the figure morph itself to off, or you can display hidden parameters for the clothes and find the automatic morph causing problem then zero it.
  • lemipslemips Posts: 23
    Ah perfect, display hidden parameters is excactly what I needed! I had tried that, but only looked in the "Hidden" tab that appeared in the morphs heirarchy, I didn't realize the other sections of Actor also had a bunch of hidden stuff!
