Is there a way to render/export a z-depth map
babel25babel25 Posts: 54
Is there a way to render/export z-depth map that can be used to drive a DOF blur in photoshop or after effects?
I found a tute here http://lantios.deviantart.com/art/Z-Depth-Mask-Tutorial-in-DS3A-170794440 but it's for Daz 3. Anything easier in 4.6?
  • SzarkSzark Posts: 10,634
    without buying anything else yes that would still be the way to do it...via Shader Mixer. If you have http://www.daz3d.com/atmospheric-effects-cameras-for-daz-studio then you can do it without the need to do it yourself. :)
  • babel25babel25 Posts: 54
    Tried the shader mixing tute in Daz 4.6. Step 5 has changed, the menu path is now bricks/functions/utility/variable [root context]. I've added a comment there about it.
    The zdepth function overrides normal rendering. How best might one get a matching normal render? Clone the camera? Turn something on/off to bypass the zdepth? It would be great if a normal rendering camera could update to match changes in the zdepth camera or vice versa.
    Also some alternative to tweak-and-render testing to set the min/max distances would be nice. Oddly they seem not to correspond at all to the cameras DOF distances.
  • prixatprixat Posts: 1,627
    I noticed a depth shader in the Shader Builder, but have not tried it yet.
