Isolating single sections of clothing for D-Force Surface Adjuster?
Is this possible somehow? I had thought maybe Geometry Selection or something but that doesn't seem to have an effect.
  • LeanaLeana Posts: 13,501
    You could indeed create new material zones with the geometry editor then set dynamic strength to 0 on zones you don't want simulated.
    Another option would be to use a dForce weight map to define which parts of the surface are influenced by the simulation and which are not. That's usually what's done for skirts which don't have a separate "belt" material zone, to prevent them from "sliding" from the hips: a dForce weight map sets polygons around the waist as non-dynamic, while the rest of the skirt is affected by the simulation.
  • Wow, two options, that's very helpful. Thanks very much!
