Animation Output Discrepancy
Hello!
An odd occurrence: I set up a simple set of expression transitions - Animation A on 0, Animation B on 60, Animation C on 120, and then A again on 179 to create a 6 second loop. When I render to a movie, the transition stops with Animation C and never transforms to A. When I render to image sequence, it does. It also transitions properly when you just scrub through the timeline.
Aroo? Thought?
TomD
hi ;) I don't speak English and I use a translator so I'm not sure to understand but why do you need to render animation A a second time? why not take your output file A and duplicate it? so that you have A(1), B, C, A(2)
you can even divide by two your renderings, if your goal is to create loops, you just have to create an animation from 0 to 14 then (outside daz studio) invert the playback order from 14 to 0 to have a perfect loop of 30 frames
again I'm not sure I understand so sorry if I'm off topic ;)
