scale HDRI domes?
Went over to HDRI Haven, got an outdoor scene, loaded the .hdr file into Render Settings -> Environment Map, loaded, but: I then added a prop, an entire lounge area and it was the size of a LEGO kit in comparison to the hdr image.
I switched dome from infinite to finite and tried changing Dome Scale and Radius, but they have no effect even with wild values.
I could scale the prop, but then I'd have to scale each and every item I add. Does not seem right. What can I do here?
  • markusmaternmarkusmatern Posts: 618
    edited August 2020
    You already mentioned some of the important settings. However did you try to change the Ground Texture Scale when working with Dome Mode: Finite Sphere w/ Ground
    Try the following as a first setup for a car: https://hdrihaven.com/hdri/?h=derelict_highway_noon
    Use the following render settings:
    Draw Dome: On
    Dome Orientation: -55.0
    Ground Texture Scale: 170
    Add a camera and position it to the following coordinates:
    X Translate: 0
    Y Translate: 170
    Z Translate: 0
    X Rotate: -5
    Y Rotate: 0
    Z Rotate: 0
    Add a car and move it in Z to about -660:
    You should get something like this:
    Instead of a car this should work with your lounge area, too.
    1920 x 1080 - 328K
    Post edited by markusmatern on
  • pixelquackpixelquack Posts: 447
    Well, but what's the scaling option after all? Ground texture scale did not seem to do anything. (That's one late reply, sorry. Need to review notifications.)
