do Victoria 4 expressions work on Genesis 2?
AristocAristoc Posts: 254
do Victoria 4 expressions work on Genesis 2 ?
Thank you
  • BeeMKayBeeMKay Posts: 7,019
    edited June 2014
    If they are poses, they should work pretty good on G2F. The result will not be 100% the same, though.
    However, you won't have the slider expressions available, since those only show up only with the character they were designed for.
    I've attached an example of V4 pose used on the base G2F.
    1253 x 769 - 126K
    Post edited by BeeMKay on
  • fixmypcmikefixmypcmike Posts: 19,708
    Expressions are done with morphs, so not necessarily. If the expression is a preset for existing dials, there may be dials with the same names on Genesis 2, so it may work, or work partially.
