Fade transitions in carrara
More2burnMore2burn Posts: 0
edited June 2014 in Carrara Discussion
saw the tut DUDU 000001 did called "Destruction M3" but I'm missing something. I can get objects to disappear in an On/Off fashion using "Visible" but I'm missing a step to make the fade. Anyone know what I'm missing? Thanks in advance.
Post edited by More2burn on
  • DUDUDUDU Posts: 1,945
    I work on the alpha channel in the shader, from 100% to 0%...
    As DUDU says, you can use a numeric slider in the shader's alpha channel. It can be keyframed.
  • DartanbeckDartanbeck Posts: 22,149
    What they're saying is that DUDU was not using the "Visible" check box. Items that have several shader domains will require than you slide down (0 = Off) the Alpha channel for each shader at the same time - or you can offset the timing if that works better for the model in question.
