Morphs deform clothing
pucaleepucalee Posts: 0
Hi,
I believe I'm almost at the final step to my first distributable clothing.
I modelled my clothing based on the basic G2F figure. After the initial rigging with transfer utility, when I turn Victoria 6 body morph dial, indeed my clothing changes according to the morph. But the issue is, I see some unwanted folds, especially under the breasts and around the crotch.
How do I tackle this? Does it have something to do with weight map?
1333 x 2000 - 1M
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Mostly it's likely to be down to the auto-generated morphs - you may need to create custom morphs that correct those issues, loading them in place of the generated morphs (you need to get the morph's name from the Parameter Settings dialogue, then enter that as the name in Morph Loader pro and set make Unique to Deltas Only so that it overwrites the generated morph.
