I forget how I did it...V4 body suit question
Some time ago I managed to make a cleavage corset-like bodysuit using the V4 bodysuit onto a Genesis female, which I saved as a wearable; which I could then use on Genesis 8 female/Victoria 8.  Okay...computer crash, long story short, while I could salvage most of my work, I couldn't save the wearables...I know there's a way to remove parts of the bodysuit so I'm left with a cleavage corset and a bottom, but I forget how!
Under what tab/sub-menu do I find the separate bodysuit parts?
Thanks guys!
  • SimonJMSimonJM Posts: 6,100
    From memory you'd load the bodysuit .cr2 and use MAT poses (.pz2 files under the Poses folder) to apply the 'styles' (done via trans maps I think).
  • comixfanacomixfana Posts: 278
    I remembered! Surfaces tab, reduce the opacity to zero on the desired parts of the bodysuit!
  • 3Diva3Diva Posts: 12,058
    Yeah. Also, if you want more procession, you could also use maps in that Cutout Opacity channel. :)
