Daz Studio stops working
Darklady5Darklady5 Posts: 29
Last Thursday, I was launching Daz Studio (4.6.3.50) but it wasn't opening up. So I took a look at the problem by checking any application or file that is probably prevent the Studio from being starting up. I found nothing and went deep by uninstalling old and reinstalling new version(4.6.3.52). Two day later, it still isn't working. I will appreciate any troubleshooting for this exasperatingly problem from you. Here is the log:
+++++++++++++++ DAZ Studio 4.6.3.52 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.6
OpenSubdiv Version: 2.3.5
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: GenuineIntel
CPU Brand String: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Cache Line Size = 64
L2 Associativity = 8
Cache Size = 4096
Stepping ID = 11
Model = 15
Family = 6
CLFLUSH cache line size = 64
APIC Physical ID = 2
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
CPL Qualified Debug Store
Thermal Monitor 2
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
Debug Store
Thermal Monitor and Clock Ctrl
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Hyper-threading Technology
Thermal Monitor
Pend. Brk. EN.
Physical Memory:
Total: 7.9 GB (8587284480)
Avail: 4.3 GB (4697952256)
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795875663872)
Current Memory Usage: 45%
Current DateTime:
Loc: Sat Jun 21 14:46:51 2014
UTC: Sat Jun 21 18:46:51 2014
Temp Data:
Location = C:/Users/Celia/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 288.2 GB (309533732864)
Disk Avail: 66.1 GB (71008010240)
Locale: en_US
No translator found.
Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Main Street.style
Creating managers
Reading help index
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/EXPExporter/ExPExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FBXExporter/FBXExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FigureSetup/FigureSetup.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/JointEditor/JointEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/LayeredImageEditor/LayeredImageEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoader/MorphLoader.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoaderPro/MorphLoaderPro.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/PolygonGroupEditor/PolygonGroupEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/TextureAtlas/TextureAtlas.dsx
  • BeeMKayBeeMKay Posts: 7,019
    If you check the task manager, is DAz Studio listed as running?
  • Darklady5Darklady5 Posts: 29
    Daz Studio wasn't listed as running however I tested it by starting it up, it was showing up for 1 second.
    edited June 2014
    Did DS run before it stopped working? And if "Yes", has something changed in between the last successful run of DS, and when it stopped working?
    Like, was something installed, a directory changed, user rights changed, etc.
    Post edited by BeeMKay on
    Yes, it did starting then stopping. And I recently installed Revo uninstaller Pro and few Adobe Creative softwares including Photoshop CC 2014.
  • DZ_jaredDZ_jared Posts: 1,316
    The next thing that DAZ Studio does when it starts is graphic card/ OpenGL related. The fact that it didn't record doing any of that indicates that it crashed performing something related to that.
    I recommend updating your video card driver or re-installing your video card driver.
    Okay, that mean I have to reinstall video card driver. Will let you know what happen when it is done.
    I did reinstalling the video card driver and restart my computer. The result is Daz studio still doesn't load. What else you may suggest?
  • bighbigh Posts: 8,147
    so DS was running before you installed these ?
    if so you could try uninstalling them - I would start with Revo .
    You are correct, DS did running well before Revo was installed. I thought of it, too. I am going to terminate it.
    No joy.:blank:
  • TotteTotte Posts: 15,155
    Sounds like you've installed something that is tampering with the OpenGL driver, your graphics card, or is just eating all VideoRAM, have you done a classic reboot?
    What exactly is a classic reboot?
    Darklady5 said:
    No joy.:blank:
    try doing a restore from when DS worked .
    edited June 2014
    The real one, shutdown, poweroff, wait at least 60 seconds to prevent any "smart soft startup things" to run before power on again.
    Post edited by Totte on
    Ah I got it!
    Still no joy!
    bigh said:
    Darklady5 said:
    No joy.:blank:
    this didn't work ?
    bigh said:
    bigh said:
    Darklady5 said:
    No joy.:blank:
    this didn't work ?
    No unfortunately. I try to think what else that stop DS from start up.
