Im having trouble installing some content i bought
halfmast88
Im having trouble installing some content i bought. I'm using the download install manager. Basically Its anything tagged as Carrara. The only products I have is Daz3D. It wants me to set file paths for some downloads but i don't know where to set it or if i even have the required
software/installers. I have included Screen Caps of what i think is the relevant data including logs and such. Thanks in advance.
1052 x 431 - 174K
540 x 387 - 37K
546 x 516 - 42K
563 x 661 - 143K
574 x 652 - 80K
If all you want to do is install the M4 Carrara shaders into Carrara, you need to set up the path, and that 3rd screenshot on the Applications tab in DIM is where you would do that.
Basically, just click the small "+" button near the bottom left of that dialog, and then select Carrara from the first drop down list, then the version number from the second drop down list. then the Bit (32 or 64, as necessary), and finally click on the three "..." button to the right of the Path input field so you can navigate to where you have Carrara content installed on your computer. Lastly, click the Accept button, and that will add the path to Carrara into your Applications tab list.
Then make sure that it's selected, and DIM should be able to do the rest.
Hope that helps.
That worked thanks.
