Is there a way to remove shadows on nvidia iray
I'm trying to render out 2d images, but it always has a shadow. I've relentlessly searched the forum, but I am still rather new and I so a lot of jargon blows past me. I read that if I took my character off the ground that would help. I was also told to try 3delight, but when I did, the render looked like garbage, just saying. Nvida iray is great, i just need the shadow off the ground.
iRay casts shadow. That's built into it. If you want to make sprites you need to turn off draw ground in the render settings. That should prevent the character casting a shadow on the ground, as there will be no ground. but it may still cast shadows on itself.
thank you very much
