What is happening with that structure
Loony
Hi, I played with a table I got, it have a fabric over it and I wanted to make holes in it, but then I saw it let pieces there... even if I did hide the Geometry.
And a bit later in the clip you can see all was "clean", I moved the camera and then it did appeared again, just by camera moving O_o
It is also visible in iray, I did forgot to record the iray view.
I used 2,5x speed to make it faster ;)
Any idea what there is going on and why that can happen and is it possible to delete the polygons then?
Video:
It's a little hard to follow the video. Is the cloth a single plane, or a flattened cube? The way that the angle of view causes it to change sounds like there is still a layer of faces that coincide with the layer defining the top of the table, which you see depends on which gets drawn first which in turn is very sesnitive to the angle of view.
Its a flat plane hanging over a table, a massage Table. there is a wood contruc,t then the matress and then this covering fabric.
and no idea about the layer of faces thing :D
