Flat Earth model, 5G phone tower, essential oils collection
WendyLuvsCatzWendyLuvsCatz Posts: 41,507
edited August 2020 in Product Suggestions
for rendering fun I think a Flat Earth model would sell well
also phone towers seem absent for our urban renders
a collection of essential oils would be nice too
no hidden agendas for doing  parody I swear devil
also maybe a multilevel marketing theme pack
party nibbles, presentation poses, plastic food containers, makeup samples
  • richardandtracyrichardandtracy Posts: 8,029
    edited August 2020
    plastic food containers?
    Why would anyone want to model containers for immitation food? wink
    Attached is a food pot obj model similar to the plastic pots used in our local Chinese Take Away. It's not texture mapped & is a converted STL model (so all triangles - started life as a SolidWorks model) with a top & bottom face to all surfaces. Do with it as you will. It's modelled in cm, so import into DS at 100% scale. There are two separate models, lid & base positioned correctly relative to each other, but one or other could be loaded independantly. When stacked, each lidded food pot contributes 2.75cm to the stack (should you need to do a linear array of them as if a stack has just been delivered).
    Regards,
    Richard.
    zip
    zip
    Food Pot - Lid and Base.zip
    62K
    611 x 328 - 26K
    Post edited by richardandtracy on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    yes
    was thinking about wuppertare but still useful
  • I probably have 200 of these food pots in my workshop, each labelled with the contents (eg 'M8 Nuts', 'Spare Drill Bits', 'Pop rivets', 'BAP 300 Carbide Insert'). Some are now nearly 20 years old and getting a bit brittle.
    Hmm, Wuppertare. Don't have much of that type of thing at home. May take a look this evening, most of what we have came as the reusable container around little individually packed cakes that my wife scoffs before I can have one. [mutter, mutter, grumble]
  • StoicStoic Posts: 157
    edited August 2020
    yes
    Did Sempie ever release that amazing tupperware freebie they were making?
    https://www.daz3d.com/forums/discussion/comment/87625/#Comment_87625
    https://www.daz3d.com/forums/discussion/comment/86410/#Comment_86410
    Post edited by Stoic on
    Stoic said:
    yes
    now that's cool yes
  • That's a good quality set Sempei did. Would be worth looking for.
    edited August 2020
    OK. Done another little model. This is a model of the little 5cm/2" diameter food pot we heated our daughter's baby food up in just after weaning some 23 years ago and we still use occasionally for 'things'. Same caveats.apply, it's a SolidWorks model, modelled in cm, saved as STL, converted to obj by my STLtoOBJ program. No texture mapping.
    zip
    zip
    Baby Food Pot - Lid and Base.zip
    193K
    438 x 479 - 21K
    How would you do a flat earth? Put one half of the globe on one side and the other on the bottom? Seems fairly easy to do, actually, just take a circular flat primitive and stick a texture on it... Maybe we need models of microchips that go inside vaccines too lol.
    as you may have gathered this was a tongue in cheek request thread,
    for parody renders
    I was being very careful not to mention the conspiracy theorists
    That wouldn't work... Flat earth has edges where you can fall off, which means no normal people can live down under.
    there are Official ones
    edited August 2020
    That cannot be an official one. Where is the Turtle? Where are the Elephants? Can you see the impact point of the fifth Elephant?
    And where are the mountains at the hub?
    Feel that would be a deeply discounted, knock-off flat earth. It would likely have a city called 'Reme' and have a strata somewhere with a fossilized dinosaur holding a placard demanding an end to nuclear weapons.
    [Cf Terry Pratchett Disc World series and his book 'Strata']
    edited August 2020
    That was the first thing I thought of.
    https://imgur.com/sHN7Hik
    https://imgur.com/6nbZ7W6
    Though it's still cool even without them.
    https://imgur.com/oA416Mo
  • SevrinSevrin Posts: 6,314
    Daz had a problem with realistic models.  It's all fantasy stuff here.
