Sauna twigs
Hi,
does somewhere excist this:
You use it in a Sauna/Spa, I have some Sauna/Spa rooms, but not that prop.
Anyone know such a product if not, would nice if some artists can create it :)
    Search this "3д модель банного веника" (=3D model sauna broom), maybe Google can find at least some of the ones Yandex found with it's image search, searching in english didn't get me anywhere and I didn't even try in finnish (not enough modellers here)
    Found a free one (FBX) on 3d-modeli.net, but doesn't look like the one in the picture or any I have used and the download link needs working protection.
    The hardcore version is of course made of juniper wink
  • LoonyLoony Posts: 1,817
    WHat is a hardcore version and what is juniper? :D
    I checked those modelli sites, but... its all in russia :/ and I dont know how FBX works... it does also look a bit different.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,514
    tie some scaled down trees together with a rope prop
    But... does trees not have too much polygons? and when I use some low poly tree for distances then it will maybe look ugly :/ I could try to use one "medium" tree and use instances on it but.... hmmm not sure.
    but a good idea. Thats how I created some twigs, I deleted the bush and just let 1 twig there :)
  • A faithful model of that is going to have a very high polygon count. What might work, for a distance, is a series of nested cones, and apply an image of leaves and twigs tot hat with a transparency map (you could make your own by rendering some tree or branch models)
    well, I make mainly closeup renders, full distance renders are very rare. So I would need some high detail stuff :/
