Mesh Grabber Tool Issues
Has anybody else experienced issues with the mesh grabber tool messing up textures on geoshells?
I was tweeking a shirt with the mesh grabber tool and I found that one of my geoshells had all it's textures wiped out...
I even had trouble putting the textures back on...luckily I had saved the scene prior to messing with it, and a reload brought things back...
JD
  • mixajirimixajiri Posts: 0
    Same here. So far, the only way to fix it seems to be to reload the scene from a previous save for me. So always save your scene before using mesh grabber. A fix or tutorial on how to fix this issue would be much appreciated!
  • dan2050dan2050 Posts: 43
    Yes, I run into this fairly often.
  • TomhipTomhip Posts: 638
    edited February 28
    I seen that happen when you save the scene with Mesh Grabber active.
    Always switch out of of the tool before you save and close/reload the file.
    Post edited by Tomhip on
    Yes, I think the key is to clean exit the tool by deselecting the target and switching to the normal pointer tool before doing anything else.
