Problem saving figures as
High bascaly i have pair of boots, whose has been saved before as a figure. Now i created a morph for a body morph. It is working as intended. But when i save the figure over and load back it uses the generated morph instead of my custom morph. If i save the figure with a different name, it loads with my custom morph.
So i decided to create another runtime folder and save another version of my product. But even i tick the check box, it does not collect the data under the new runtime but only the figure file.
I had a little search with my item name and i found there is files with my item name under a folder named 4_0_2. I saved as the figure and deleted the folders with old file name but the item did not load.
Can you explain me how the system works. And how can i solve the problem as quick as possible.
Hey, i know more/less what problem your having, a bit confusing when reading what you posted, BUT, i think this page will help http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/packaging/tutorials/packaging_genesis_morph_products/start
Thank you for your reply it solved my saving as problem but i still dont know why it doesnt save my custom morphs when i save over.
