Is the current version of DAZ Studio faster than the previous one?
While I had never upgraded to the last version of DAZ Studio since last year, I just installed DAZ again. And on my under-performing computer, it seems significantly faster. For instance, an Iray preview loads very quickly while it was sometimes taking ages before.
The only other explanation would be that having a lot of content in the library slows down DAZ Studio (since having just installed it, my library is almost emty), but I can't see why it would.
  • Noah LGPNoah LGP Posts: 2,617
    Daz Studio 4.11 was slower than 4.10
  • kenshaw011267kenshaw011267 Posts: 3,805
    Depends on what you mean by faster and what version you're comparing.
  • Gr00vusGr00vus Posts: 372
    Having a lot of content seems to cause the initial load of the Studio software to take a long time, but after that I don't notice any impact performance wise related to amount of content.
    My experience has been that 4.12 is slower than 4.10 for me when rendering in Iray. I think it has to do with how support for OptiX accelleration has changed between the versions, as I have a 980Ti which benefitted from the older Iray implemenation/OptiX accelleration which has been changed/removed from recent versions, whereas newer versions have been optimizing for RTX architecture cards (the 980Ti is not RTX). What kind of graphics card do you have?
  • mmkdazmmkdaz Posts: 335
     I think it's "faster" but it takes up more memory than the previous version in IRAY so if you have a slower computer (like me) the result is a slower program.
  • odasteinodastein Posts: 606
    I mean faster when I work on the image. Elements load quicker, there's no slow down when I move stuff around or pose, Iray preview appears quicker. The rendering isn't faster, though.
  • SevrinSevrin Posts: 6,314
    That's probably because you haven't installed your full library.  What slows loading down is all the morphs you own, whether you use them or not.
    Even if I didn't even load a character, the morphs would increase loading time?
    Also, would the morphs affect as well the time needed for an Iray preview?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,510
    good question
    4.11 was certainly faster with my inferior 980ti GPU
    but if you own an RTX card I think the later versions are
