Genesis 8 body morphs
I have Daz Studio 4.12 pro. And I loaded the Genesis 8 character into the studio and it morphed. Not the entire body, just the hips and mouth. And the same morph happens when I load any Genesis 8 character. And that morph stops me from using any other morph. I tried to reinstall the character, and it still morphs. I tried to reinstall the studio, and it still morphs. The only way to stop it from doing that is to load the morphed Genesis 8 character, zero the body shape, find the characters body shape that I want to use and apply it. Is there anything that could be done about that?
  • scorpioscorpio Posts: 8,534
    You have probably installed something that overwrote the Genesis 8F base you need to find the character/morph and unistall it.
    That is the result of badly packaged morphs/characters installed in your system, they have morphs saved with non-zero default value.
    Re-installing Starter Essentials does not work, because the problem is not with the base figure but the morph/character that has been installed.
    To fix any ill-behaving morphs, do as follows;
    1. Load your base figure or the developer version.
    2. Select "Show Hidden properties" in the Parameters-Tab, drop down menu (right-click)
    3. Zero the figure (Found in Parameters-Tab, drop down menu)
    4. Memorize the figure (Found in Parameters-Tab, drop down menu)
    5. File->Save As->Support Asset->Save Modified Assets
    This procedure will zero the default value in the ill-behaving morph/morphs, and while saving DS also shows you a list of the morphs it is changing.
