Shattered Glass Question
https://www.daz3d.com/shattered
This is a great product I want to purchase, but I don't think it is Iray.
So my question is will it work in an Iray render? Something like what is shown in this promo image below is what I want to create.
I do not use 3Delight, but have noticed many 3Delight props work in Iray scenes just fine.
I have only had trouble with environment products that do not render in Iray, showing only a black screen. But I'm hoping I can add this product to my Iray renders. I'm not sure what the difference is with 3Delight Environments vs. Props, or why some do not render in Iray and others render just fine.
Post edited by vonHobo on
I would think that you could hit it with an Iray glass shader and it would be fine. But I don't use Iray if I can avoid it, so I'm not the best person to ask.
I do know that Iray glass shaders are pretty thick on the ground.
Product page says: There is no opacity or displacement map trickery here, instead every crack, hole and fragment is presented in actual 3D Geometry.
So should work.
Thanks for the info. Sounds like it's doable. :)
Applying an Iray glass shader from the DAZ Uber set gives excellent results.
It is. I've used it with Iray a couple of times, here, (the broken mirror,) and here.
I've also used it in Iray with some Iray glass textures it does just fine.
Thank you everyone!
Nice image!
Very nice images! Thank you!
