looking for Sci-fi/cyberpunk style goggles
FabeFabe Posts: 232
edited June 2014 in The Commons
Anyone know where I might find a pair of sci-fi or cyberpunk style goggle, like the kind that might be used to display information to the wear? I tried a search here but it did look like got any promising results.
Post edited by Fabe on
    Try Shadowcrol by Inception8 over at Runtime DNA. They are permanent deep freeze sale so they run about $3 for the set. Also check out his Syntax package as well.
    RDNA's site will be going down as of Midnight tonight for a massive update. The galleries and the forums will be up in a couple of days but the store will be offline until around the 25th of the month. So if you need to buy them do it before midnight tonight Eastern Time US.
  • srieschsriesch Posts: 4,243
    I see it is now available here at DAZ, http://www.daz3d.com/shadowcrol
    Although the product is for V4, has anybody tried fitting any of the items in this product to Genesis1?
  • mtl1mtl1 Posts: 1,508
    I've purchased the item recently. Give me a few moments...
    I've done some quick renders to check the fits. The 'front-only' ones tend to work fairly well, although there's a slight offset that can be fixed relatively easily before parenting. The ones that go behind the ear and head will need adjustments, either with d-former or with the built in morphs. But then again, that's not much of an issue if there's hair...
    2000 x 1000 - 3M
    2000 x 1000 - 3M
    2000 x 1000 - 2M
    2000 x 1000 - 2M
    2000 x 1000 - 3M
  • kaotkblisskaotkbliss Posts: 2,918
    Looks like a couple nudges on the scale x to make them a hair wider could fix the ones that go behind the ear
