Mesh Grabber Question?
Hello Friends,
Ive been using this amazing game changer for a few weeks now and I'm only scratching the surface on its capabilities.
I do have a burning question though. Is their anyway to undo the morphs I made with it? What Im finding is after a scene is completed and I used the Grabber early on its not feasible to step back 50 times to reverse its effects. I'm hoping there is some easy way to restore whatever back to normal?
Thanks in advance!
A
  • SkelchSkelch Posts: 278
    I feel your pain I started doing incremental saves just for this reason, and it sucks quite a bit when I forget
    If you have not been saving the morphs, simply deleting the clothing and loading a fresh copy will get you back to the starting point.
  • ManFridayManFriday Posts: 569
    When the Mesh Grabber is active and an object with active deltas is selected, you can right-click and select "Reset Mesh Grabber" like in the screenshot. Is that what you're looking for?
    There is also a "Reset..." button in the Tool Settings pane when the Mesh Grabber is active, which does the same thing. In both cases, it only removes the deltas from the currently selected object, but you can't undo that, so there's an extra confirmation box.
    523 x 496 - 38K
