Horror10 coupon not working now?
Kharma
Is the code for this coupon no longer in effect? I have 2 items in my cart from the horror items which total 11.86 but when I apply the coupon code I get the dreaded "coupon not valid: error!
I used my Horror Coupon yesterday and it worked.
I checked the Sci-Fi Coupon, now and it works, too.
it works on items individually over the 3 dollars.
i ended up using it on the guildhall waterfountain. wasn't something i wanted but was getting desperate to use the coupie.
now i feel like i need the rest of the guildhall. >.< :)
I have Armageddon ( $4.19) and family grave in($7.67) my cart, both from horror category, total $11.86 and the code says not valid...why? /they are both more than 3.00 and both in the category that I can choose from, what other limitations apply to make this coupon practically non-usable?
no other limitations.
copy the code
C2S-HORROR10
and try it again.
only other thing i can think of, if you have an extra space in the code? even an extra trailing space would mean invalid.
if the code does not work for you open a support ticket
Now I am thinking maybe I already used it? How would I know? I have looked through prior orders and they don't show if you used a coupon on the order. Would be nice if it either showed on the order or the coupon was removed from your account once used so there is no confusion, and no waste of time for anyone in checking to see if that could be a reason for invalid response.
