G8F Morph to G8M? Elf Ears?
MelissaGTMelissaGT Posts: 2,611
Hi there,
I have a fanart commission I'm hitting a roadblock on. It's for a male Blood Elf (World of Warcraft). However, I haven't found a single morph for WoW elf ears...for MALES. They're all for females. Is there a way to transfer the morphs I have for females over to a male? I know I can try to finagle something with mesh grabber or my extremely limited ZBrush abilities...however, the female WoW elf ears I have are really nice (Mousso's)...and whatever I make will not be up to snuff for me to put into a paid commission.
I've seen folks mention in other threads that I should be able to use the G8M clone and make him on the G8F base...however I'm not sure I'd be able to replicate the character I need to make facially because then I'd be limited to the female morphs I have for faces. I do have the UV swap utility, so texture is not an issue...but ideally, I'd like to just be able to transfer the elf ears over so I can use them on the male figure.
Thanks!
Post edited by MelissaGT on
  • GordigGordig Posts: 10,797
    You can use the Transfer Utility to transfer morphs across genders. Try the settings I posted in this thread: https://www.daz3d.com/forums/discussion/402716/g8f-chimp. Favorite the ears morph first.
    edited July 2020
    I'll take a look...I tried to use the transfer utility to import the morph as a morph asset but no potatoes. I'm sure it was something I was doing wrong, as my extent of knowledge for morph importing is with clothing, etc.
    *edit* Ooooh it worked! I heart you!
    Are you sure you were using the Transfer Utility and not Morph Loader? Transfer Utility doesn't "import" anything. Glad you got it working. Remember to save that morph asset!
