Trick to get Carrara opening or working
My Carrara pro never want open on my windows 10 again!
So has a programmer without a code source, I had to try a lot of way to be able to open this modeling tool again without breaking my windows 10.
So the best way I think who work for me was installing Oracle virtual Box on windows 10, and in Oracle I Installed a copy of my windows 8.1, and share a folder, and Daz Data folder, after that I installed Carrara who open like a charm.
You just need a big hard disk.
It’s a trick for old tool or software.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,566
    try removing any extra plugins from extensions if you havd any
    also do you have a drawing tablet?
  • DiomedeDiomede Posts: 15,459
    Thanks for the tip.  At the moment, Carrara 8.5 Pro still works with my Windows 10 system.  Just a matter of time before an update causes a problem, though.
  • VyusurVyusur Posts: 2,235
    I also work on win 10 and I draw with graphic tablet, and Carrara still works for me.
    it depends on the graphic tablet
    there is one that breaks it irreparably with its driver
  • PGrePGre Posts: 95
    I have a HUION Tablet and the driver for it must be running in order to open Carrara. Every time I restart Windows 10 I need to restart the tablet driver (the HUION installer puts a shortcut on the desktop).
  • CbirdCbird Posts: 493
    Thank you for this info, PGre. I just bought a Huion and haven't set it up yet. I was wondering if I was going to need to use it on a separate machine.
    I also use Huion. Not every driver works well, some of them evoke system conflicts. But my very recent driver works fine.
  • NostreNostre Posts: 11
    Yep I got the Huion tablet driver, now disable, I completely uninstalled and installed a fresh copy of Carrara still the same not opening.
    I know it’s an incompatibility between the 2, but it’s working the other way till he is updated (not sure about that it’s old) but I like the diversity in modeling.
    Thanks for sharing
  • HeadwaxHeadwax Posts: 10,562
    thanks for the tip @Nostre
  • chickenmanchickenman Posts: 1,202
    I went through this a few years ago and i had to uninstall the Huion tablet to get Carrara to work. Once the tablet was uninstalled everything workd fine.
    I even had a ticket open with support and they could not figur it out and only said it must be an issue with your system and drivers.
    I know it was in a post on here as i kept updating it but cant find it now.
    I even bought anouther another SSD to install windows and Carrara on again which worked until i added the Table Driver.
  • Bunyip02Bunyip02 Posts: 9,345
    https://www.daz3d.com/forums/discussion/255036/preferences-file-carrara-crashing
    Just to be clear, is this the way it is whether or not Tablet-mode is enabled in Carrara? If so, that totally bites!
    I have a Wacom Graphire 3. Works great but I don't when I'm trying to use it. I just haven't had the patience to get used to it. I even tried it in Carrara 8.5 - and it worked, but I just didn't care for working that way, even when in 3D Paint which is why I was trying it. Maybe I should break it out and give it some love again.
  • I was able to run Carrara 8 on Windows ELEVEN by using Compatibility Mode for Windows 7 on all the .EXE files.
