Genesis 2 Male Anatomical Elements UV Problem
michaelt0990michaelt0990 Posts: 0
edited July 2020 in New Users
Hello, I just started using daz studio and encountered a problem;
I use genesis 2 characters and I started working with brodie 6 when I added genesis 2 male genitals to the character, the uv map did not fit and I couldn't adjust it, I tried adding metarial and shader but it didn't work,
Please can you help me with this, how do i add gen to brodie 6 character?
  • Richard HaseltineRichard Haseltine Posts: 112,089
    Daz does not support the use of the anatomical elements on underage characters.
  • So you say I can't change UV?
    The problem is not only for brodie 6 character, it does not support uv map when i apply to any genesis 2 male character, genital only supports the michael 6 character...
    Are there any actions or plug-ins that can be done to match the uv of other characters?
    As I recall there is only one UV set for the anatomical elements. You can't just apply the body maps - they have their own map, for characters that support the anatomical elements at all.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,851
    edited July 2020
    nm
  • Well thank you for your answer,
    I have checked about the uv issue in the forum before, but there is no clear answer, I guess there is no solution to this problem but...
    I will check if you have any other ideas, feel free to answer.smiley
  • What exactly are you trying to do? What exact figure are you using?
    It could be that the figures you use do not have a Texture map for the anatomical elements. For instance, there is no Teen Brodie 6 genitals texture because it does not exist. This has NOTHING to do with the Michael 6 UV.
    (As stated, the anatomical elements has one UV, universal to all Genesis 2 figures.)
    Other figures may have the textures, but they might not load automatically when you load in the character skins.
    There really shouldn't any UV issue with the anatomical elements because there's only one UV.
