Character portrait rendering
OlorinOlorin Posts: 46
I have Daz 4.6 and I am trying to render my character in close up renders. I keep getting a kind of flat appearance to her skin even with SSS shaders by Age of Armor applied. I think it probably has to do with my rendering settings. This is how I have it set up. Does anyone know what I should adjust to get better results.
I have noticed that there is a 3Delight error message up in the render progress screen that says message #42 (severity 1):P1044: invalid exposure argument. Does anyone know what that means and if that could be affecting the quality of my render.
I have raised the render quality to 4 and in the advanced screen I am rendering 1000X1300
I left progressive rendering unchecked
Bucket order Horizontal
Bucket size 32
Raytrace depth 5
Pixel samples 42
shadow samples 16
shading rate .2
all else is at default setting
    edited June 2014
    I'd recommend using Adam's render profiles. They're so handy and give great results.
    http://www.daz3d.com/forums/discussion/16085/
    I use "high" most often from his presets.
    Ray depth: 4
    Pixel Samples XY 8/8
    Shadow Samples 32
    Gain 1.0
    Gamma OFF
    Shading Rate .20
    Pixel Filter: Sinc
    Pixel Filter Width XY 8/8
    The issue could also be lighting. Can you provide an example render so maybe someone can see where things are going wrong?
    Post edited by Lissa_xyz on
  • JaderailJaderail Posts: 0
    Sounds much more to me to be a lighting in use issue. What is the lighting set up like?
  • OlorinOlorin Posts: 46
    edited June 2014
    Thanks to both of you for answering. I did play around with the lighting settings some more and then realized that it is definitely the lighting. I am fairly new to using Daz, so I guess It is going to take me awhile to figure out how to do a decent render in it.
    Post edited by Olorin on
    edited June 2014
    If I can offer a suggestion.. Age of Armour's Advanced Ambient lights are some of my faves. I've since taken to using those instead of domes. 1 light will give you diffuse, specular, and ambient (before, ambient would be obtained by using an UberEnvironment dome, which often meant a good hike in render times depending on quality settings).
    Here's the bundle with all 3 lights: http://www.daz3d.com/advanced-daz-studio-light-bundle, but if you're going to only get 1, I'd say the Advanced Ambient Light would be it since it can be used as a global fill.
    I second the AA bundle. I use it exclusively in my promos now and it is faster and gives better results than any combo I've tried before.
