Genesis 2 female always defaulting to Olympia
ChromaDrakeChromaDrake Posts: 288
edited June 2014 in Daz Studio Discussion
This is a minor annoyance but I thought I would ask anyway, every time I load the Genesis 2 female, the model loads up with the Olympia body. I have to always go to the Parameters and reset the Olympia dial from 1.0 to 0.0. No other morph does this (thankfully).
If I wanted to load Olympia, I would load Olympia from the content library. How do you set the Genesis 2 base female so it loaded as the base, not the Olympia morph?
For what it's worth, I have uninstalled and re-installed my content already because of an unrelated problem (at least I think it's unrelated, it is an issue of morphs in the Parameters tab).
Post edited by ChromaDrake on
  • nakamuram002nakamuram002 Posts: 822
    edited June 2014
    I had the same problem with Giselle. I zeroed my character back to G2F and re-saved her. Go the the Parameters Tab, click on "Options" and select "Zero" - "Zero Figure." Save as a a "Support Asset" - "Figure/Prop Assets". I overwrote my original G2F.
    Post edited by nakamuram002 on
  • JaderailJaderail Posts: 0
    Or just Uninstall G2F essentials and then Re-Install. Easy if using DIM.
  • ChromaDrakeChromaDrake Posts: 288
    I've uninstalled and reinstalled all of my content a couple of times now using DIM. No effect.
    edited June 2014
    there are three case.
    Case1.
    one of Olympia morph files .
    (as you said, it seems master controller of Olympia,which auto changed value to 1.00)
    CTRLOlimpia.dsf cause problem.
    Go to parameter tab, Actor>people>realworld>Olympia (CTRLOlymipia)
    then cliick the little gear icon and check parameter setting.
    If the default value have changed to 1.00 , then it was recorded in CTRLOlimpia.dsf
    it can cause such problem.
    About this case,, your all gen2femal character preset (gen2female, V6, or Gaia.dfu)
    may load with Olimpia.(value 1.00)
    then you only need uninstall and re-install Olympia products.
    you can use save modified assets, but I recommend,
    just un-install and re-install Olimpia products.
    original product CTRLOlimpia.dsf should be zero as default value.
    anyway I recommend try it frist.(if you have not done,,)
    Case2
    your genesis2female.duf (character preset) recorded CTRLOlimpia value and current value as 1.0
    about this case, it can change CTRLOlimpia.dsf setting too.
    then you need to un-install and re-install genesis2female.duf
    the file should be included in genesis2starter essential kit.
    About this case , Nakamura002 sugested way work well.
    (but it can not change CTRLOlimpia.dsf default value, I think)
    Case3
    Nowdays,, I have seldom seen this case, but I easy re-produce same problem , to use another ERC morph.
    there should be another controller which auto change Olimpia morph value.
    when you use genesis2female.duf , it load gen2female. with all morphs (default values)
    if another controller work to change CTRLOlimpia current value to 1.00,
    even though you have un-installed or re-installed
    genesis2female, or Olimpia products, it can not solve your problem.
    can you show me, the Olimpia morph setting, in parameter tab.
    then check "controller"section, under Parameter setting window.
    if your prolbem not case 1 and case 2.
    there should be another character morph, or contollers.
    one of them may cause this problem for you.
    I forget to add, you may need to check samething about
    FBMOlimpia too.. but what you need is same .
    check default value, current value, and Controller section.
    1162 x 719 - 152K
    1144 x 659 - 130K
    Post edited by kitakoredaz on
