Old V4 morphs and GenX2 Questions
BurstAngelBurstAngel Posts: 763
I have an old morph by Liquid Rust that I really love, Violet for V4, I only want to transfer the head morph to Genesis 2 Female. Unfortunately, LRP did not make the head a separate morph. What steps do I need to do in order to only transfer the head morph?
Thanks!
    edited June 2014
    IIRC, throw V4 into the transfer window to get her loaded, and since Violet's head is completely custom, just throw in the INJ file after throwing in V4. Right click the window and do a transfer on for non-zero. Now go back through and scan for all of the ones that have checks on the left, and uncheck anything dealing with the body and transfer from there.
    /edit
    With any luck, the custom morph is in the head region and you can just open up the >head section in the morph window, highlight all of the head morphs (highlight the first morph in >head, scroll down, hold shift, and click on the last morph in the >head section) and do right click > highlighted > transfer on for non-zero.
    Post edited by Lissa_xyz on
  • BurstAngelBurstAngel Posts: 763
    edited June 2014
    I wish it was that easy. The morph does not show up unless I create CR2 file of V4 with the morph. I load the new CR2 into genx2 to transfer it over to GF2. The INJ morph is in the body, not the head so there is not way to separate it with in genX2, so I'm trying to figure out a way to work around it.
    Post edited by BurstAngel on
    When you throw the CR2 in and do the transfer on for non-zero, set the mode option at the bottom to Selected Morphs (with Controller) option and see if that method will allow you to dial the head region separately once transferred.
    Sorry, didn't work. I need to figure out how to create just the head morph before using genx2.
    edited June 2014
    Do you have Poser? If so, load V4 and inject the morph into her there, then export her out as an obj and use that as a morph target on V4's head. It might work if you do that same process in DS using morph loader, but I thought morph loader was for TriAx figures only.
    edited June 2014
    I did make a obj file just need to figure out how to make a morph target out of it within DAZ.
    I think I found a tutorial, Thank You, Vaskania, for your help.
    Morph targets for Gen4 or lower from within DS is where my knowledge fails. I've only made morphs for those in Poser. Hope you're able to get this sorted. :)
