How to undo the effects of an Iray clipping plane?
Hi all,
I had an Iray clipping plane in a scene, and I merged that scene into another. I removed the clipping plane, saved the merged scenes as one Scene, and even exited and relaunched DAZ Studio. However, the character from the scene that originally had the clipping plane is still being clipped out below floor level. Where do I turn this off? I assumed just removing the plane would be enough.
Thanks!
  • barbultbarbult Posts: 27,501
    That should have worked. Are you sure you don't have an HDRI in Render Settings with Manual ground level that is visibly cutting the character off?
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Is Draw Ground on in Render Settings?
  • Alley RatAlley Rat Posts: 407
    You were both right. I didn't have an HDRI loaded, but I did have a manual ground level (that I don't remember setting, so I am guessing I deleted an HDRI in the original scene), and I had Draw Ground on. Thank you both.
