Is their a plugin to control prop and character placement
Is there any plugin or am I missing something.  Is there a way to  log a figure exactly where you want it vs having to move it all around?  Could I just point and click where I want the character in the scene?  Any ideas?
    I keep forgetting which key it is, I think it's Alt, hold it down while dragging the icon to the viewport and a target will appear so you can move it around to the right place.
  • Its like that?I'll check it out!  Cool
  • That alt trick worked.  Thanks so much
  • takezo_3001takezo_3001 Posts: 2,041
    edited July 2020
    Well would you look at THAT, I've been using this prog for a decade and a half, and still I learn something new with this program! Thanks for the info!
    Post edited by takezo_3001 on
  • jaebeajaebea Posts: 456
    Omgosh, me too!!  That was so helpful!
  • macleanmaclean Posts: 2,438
    edited July 2020
    Once objects/figures are in the scene, you can also use the Align pane to position them. It's extremely useful for lining things up, stacking them, etc.
    Edit - Alt is your friend. Es. ALT+left-click on any parameter will zero it (or return it to whatever the default is). Same thing with Surface values. For some reason, a lot of people don't know that one.
    Post edited by maclean on
    because there is no documentation? Anybody remember RTFM?
    Alt drag Icon.. will tatoo that on the screen.
