rename shaders
This seems like a really simple thing, but I don't see an intuitive way to do it. How do you rename textured attatched to an object in Carrara?
  • DiomedeDiomede Posts: 15,469
    edited July 2020
    In the lower right corner of the Assemble Room is a box with multiple tabs
    Instances : Objects : Shaders : Sounds : Clips
    Select the Shader tab
    A list of the current shaders in your scene appears
    Select the shader that you want to change the name of
    A new menu will appear in the upper right with a slot for the name
    Change the name as desired
    1210 x 952 - 211K
    aa02 in lower right there is a shade rab can see current shaders in scene 2.jpg
    1328 x 947 - 215K
    aa03 select shader in lower right and see info in upper right include name shader 2.jpg
    1273 x 917 - 189K
    1192 x 928 - 168K
    aa05 back in main instances tab select sphere and see shader in upper right says sphere shader 2.jpg
    1267 x 950 - 249K
    Post edited by Diomede on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,819
    if you want to rename the actual surface too,
    go i to the vertex room with it selected,
    on the near bottom right check the global tab and you can rename them
