Errors in Toon Generations 2 (Genesis 3)
Hi, everybody.
I have a problem with Toon Generations 2, in male and female:
- In Male, the hair and mustache usually give me image problems.
- In female, the heels don't fit well as you can see.
Any solution please? I've tried a lot of things and I can't find it.
Thanks in advance.
623 x 458 - 90K
623 x 459 - 84K
  • Richard HaseltineRichard Haseltine Posts: 111,430
    Are these items made for the Toon Generation 2?
  • Dan9000Dan9000 Posts: 6
    No, but other things that are not for toon generations 2 do work, only high heels, moustache and some hairstyles fail.
  • GordigGordig Posts: 10,805
    That's fairly typical of toon characters, actually.
    The problem is that DS has to project the morph into the items, which it does by trying to keep the relative positons the same. When a morph changes the shape disproportionally, as with the head here, that is likely to produce an abrupt step as the model goes from being closest to the ehad to being closest to the neck. I'm not sure what is happening with the shoes, assuming they are fitted items rather than parented props - unless perhaps they have a Rigidity group applied.
    Thanks. Any tricks to solve it?
    Please
    Not really, that I am aware of. A projection morph might be an option (essentially a different, hidden, shape that is used for morph transfer but isn't available for shaping) but even then I'm not sure how much of an improvement it would be.
    Parent it to the figure instead of fitting  it.
    Yeah, you have to parent & then size & position the problem product
    Thanks. I'll try to do that. smiley
