Strand-based hair crashing my system
OK, so I'm running an Intel i5-4590K CPU @ 3.50 GHz with 16 GB with a GeForce GTX 1050Ti with 4 GB. Drivers are up to date. I'm trying to render a relatively simple scene with few props and when I try to use strand-based hair, it freezes up my entire computer, to the point where I have to hit the reset button on my case.  Any suggestions or help would be greatly appreciated.
Here's the output of my log file:
2020-07-21 07:25:34.658 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : NVIDIA display driver version: 451.672020-07-21 07:25:34.663 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : Your NVIDIA driver supports CUDA version up to 11.0; iray requires CUDA version 10.2; all is good.2020-07-21 07:25:34.668 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : Using iray plugin version 5.1, build 327300.3640 n, 30 Mar 2020, nt-x86-64-vc14.2020-07-21 07:25:34.855 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : CUDA device 0 (GeForce GTX 1050 Ti): compute capability 6.1, 4.000 GiB total, 3.306 GiB available, display attached2020-07-21 07:25:34.857 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : CUDA device 0 (GeForce GTX 1050 Ti): WDDM driver used, consider switching to TCC driver model if no display needed (via 'nvidia-smi -dm 1'), to increase rendering performance2020-07-21 07:25:34.857 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : iray photoreal CPU fallback is enabled.2020-07-21 07:25:34.868 Iray [VERBOSE] - IRAY:RENDER ::   1.1   IRAY   rend stat : Environment cache size capacity: 5.2020-07-21 07:25:34.876 Iray [INFO] - BLEND:RENDER ::   1.1   BLEND  rend info : Plugin "blend render" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.876 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_cloud" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.877 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "irt_cloud" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.877 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "nitro_cloud" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.877 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iq_irt_cloud" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.902 Iray [INFO] - IRT:RENDER ::   1.1   IRT    rend info : Plugin "irt" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.908 Iray [INFO] - EIAXF:IO ::   1.1   EIAXF  io   info : Plugin "axf importer" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.908 Iray [INFO] - ICB:IO ::   1.1   ICB    io   info : Plugin "cb_importer" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.908 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_bridge_snapshot" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.908 Iray [INFO] - IRAY_CLOUD_SERVER:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_bridge_server" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.908 Iray [INFO] - EEMI:IO ::   1.1   EEMI   io   info : Plugin ".mi exporter" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.914 Iray [INFO] - EIMI:IO ::   1.1   EIMI   io   info : Plugin ".mi importer" (build 327300.3640, 30 Mar 2020) initialized2020-07-21 07:25:34.942 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1050 Ti): compute capability 6.1, 4.000 GiB total, 3.306 GiB available, display attached2020-07-21 07:25:34.944 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1050 Ti): WDDM driver used, consider switching to TCC driver model if no display needed (via 'nvidia-smi -dm 1'), to increase rendering performance2020-07-21 07:25:34.944 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : iray photoreal CPU fallback is enabled.2020-07-21 07:25:34.944 Iray [INFO] - IRT:RENDER ::   1.0   IRT    rend info : Resource assignment for host 0 has changed.2020-07-21 07:25:34.944 NVIDIA Iray GPUs:2020-07-21 07:25:34.944 	GPU: 1 - GeForce GTX 1050 Ti2020-07-21 07:25:34.944 	Memory Size: 3.9 GB2020-07-21 07:25:34.944 	Clock Rate: 1430000 kHz2020-07-21 07:25:34.944 	Multi Processor Count: 62020-07-21 07:25:34.944 	CUDA Device ID: 02020-07-21 07:25:34.944 	CUDA Compute Capability: 6.12020-07-21 07:25:34.944 	PCI Bus ID: 12020-07-21 07:25:34.944 	PCI Device ID: 02020-07-21 07:25:34.945 	TCC Mode: disabled2020-07-21 07:25:34.945 	Display: attached2020-07-21 07:25:34.949 NVIDIA Iray Scheduling Configuration:2020-07-21 07:25:34.949 	CPU Load Limit: 42020-07-21 07:25:34.949 	CPU Thread Affinity: disabled2020-07-21 07:25:34.949 	GPU Load Limit: 12020-07-21 07:25:35.645 Total class factories: 21572020-07-21 07:25:35.653 Creating Script Engine...2020-07-21 07:25:35.722 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed2020-07-21 07:25:35.723 3D mouse support library could not be loaded.2020-07-21 07:25:35.748 Creating Main Window...2020-07-21 07:25:35.776 Creating Viewport Manager...2020-07-21 07:25:35.935 Successfully created OpenGL viewport for Viewport1.2020-07-21 07:25:36.134 Successfully created OpenGL viewport for Viewport2.2020-07-21 07:25:36.258 Successfully created OpenGL viewport for Viewport3.2020-07-21 07:25:36.398 Successfully created OpenGL viewport for Viewport4.2020-07-21 07:25:36.785 Creating Action Manager...2020-07-21 07:25:36.900 Creating Pane Manager...2020-07-21 07:25:37.567 Successfully created OpenGL viewport for AuxViewportView.2020-07-21 07:25:40.404 Executing startup script...2020-07-21 07:25:40.590 Started in: F:/DAZ/DAZ 3D/DAZStudio42020-07-21 07:25:40.590 DAZ Studio Started2020-07-21 07:25:40.601 Creating Pixel Buffer2020-07-21 07:25:41.023 Pixel buffer - Width: 1024 Height: 10242020-07-21 07:25:41.077 Compiling OpenGL Shader...2020-07-21 07:25:41.081 Fragment Shader:Fragment Shader compiled successfully.Linking Shader:Shader Program successfully linked.
  • Have you tried to lower your render tesselate down to 2 or even 1 from default of 3?
  • Matz21Matz21 Posts: 19
    Where do you do that at?
  • lilweeplilweep Posts: 2,864
    This is a post from July 2020... SBH is way less buggy now than it used to be.
    Anyway, tesselation is under parameters.
