problems with Daz Central and Install manager
I can't get my recent purchases to install through either Daz central or the Install Manager. Tried uninstalling and reinstalling them both, restarting the computer, resetting the internet connction and nothing works. I've installed hundred of items into my Daz library and this is the first time I've had any trouble.
«1
  • fixmypcmikefixmypcmike Posts: 19,735
    Is it failing to download or failing to install?  What OS and security programs?
  • Won't install. No security other than the same ad blocker I've had for over a year now. Windows 64. What's odd is it installed the Orestes Witches Twighlight but nothing else. I have changed nothing to my computer settings or the install programs.
    Windows 10?  Any recent updates?
    What does the DIM log say?
  • Whenever I use the Install Manager all it says is Install failed! Daz central just goes right back to Install instead of Open. I really don't want to install all that stuff manually.
  • windows did an update last night. Can't make heads or tails from the goobledegook in the DIM log.
  • This is what the log has to say:
    +++++++++++++++ Install Manager Helper 1.1.0.67 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.7
    Locale: en_US
    Running on Windows Unknown, Build 9200, No Service Pack Installed
    Physical Memory:
    Total: 3.9 GB (4294967295)
    Avail: 3.9 GB (4294967295)
    Virtual Memory:
    Total: 3.9 GB (4294836224)
    Avail: 3.8 GB (4096069632)
    Current Memory Usage: 20%
    Current DateTime:
    Loc: Sat Apr 1 12:34:49 2017
    UTC: Sat Apr 1 19:34:49 2017
    Application Data:
    Location = C:/Users/Drew/AppData/Roaming/DAZ 3D/InstallManager
    Disk Total: 931.0 GB (999677751296)
    Disk Avail: 904.1 GB (970842521600)
    Helper application data path: C:/Users/Drew/AppData/Roaming/DAZ 3D/InstallManager
    WARNING: dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server.
    Make sure the server address and port number are correct.
    Error connecting to CMS
    Current Content Install Path:
    Location = C:/Users/Public/Documents/My DAZ 3D Library
    Disk Avail: 904.1 GB (970842513408)
    Current 64-bit Software Install Path:
    Location = C:/Program Files
    Disk Avail: 904.1 GB (970842525696)
    Current 32-bit Software Install Path:
    Location = C:/Program Files (x86)
    Executing post install file: C:/Users/Drew/AppData/Local/Temp/DAZ3DInstallManager/InstallTemp/run_vc5and10_x64.bat
    Finished Process: C:/Users/Drew/AppData/Local/Temp/DAZ3DInstallManager/InstallTemp/run_vc5and10_x64.bat
    Executed install script: C:/Program Files/DAZ 3D/DAZStudio4/register_file_ext.dzime
    Executed install script: C:/Program Files/DAZ 3D/DAZStudio4/plugins/install_dynamic_clothing_basic.dzime
    Executed install script: C:/Users/Drew/AppData/Local/Temp/DAZ3DInstallManager/InstallTemp/finalize.dzime
    Product successfully installed : DAZ Studio 4.9 (Win 64-bit)
    Product successfully installed : Scene Builder for DAZ Studio
    Executing file: PostgreSQL CMS_9.3.4_(64-Bit)/DAZ 3D/PostgreSQL CMS/im/initialize.dzime
    Database Server:
    Queuing uninstall of package(s) that conflict with 18869-2...
    Executed install script: zip:/PostgreSQL CMS_9.3.4_(64-Bit)/DAZ 3D/PostgreSQL CMS/im/initialize.dzime
    Connected to CMS: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
    Database Server: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
    Executed install script: C:/Program Files/DAZ 3D/PostgreSQL CMS/im/finalize.dzime
    Product successfully installed : PostgreSQL CMS (Win 64-bit)
    Executing file: Temp/initialize.dzime
    Queuing uninstall of package(s) that conflict with 13173-2...
    Executed install script: zip:/Temp/initialize.dzime
    Executing post install file: C:/Users/Public/Pixologic/GoZApps/DAZStudio64/GoZLocateDazStudio.bat
    Finished Process: C:/Users/Public/Pixologic/GoZApps/DAZStudio64/GoZLocateDazStudio.bat
    Product successfully installed : GoZ for DAZ Studio 4.9+ (Win 64-bit)
    Product successfully installed : Inside the Asylum Guided Tour for DAZ Studio 4.8+
    Product successfully installed : Day at the Beach Guided Tour for DAZ Studio 4.8+
    Product successfully installed : Michael 4 Base Puppeteer StudioCF
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.7
    Locale: en_US
    Physical Memory:
    Virtual Memory:
    Avail: 3.8 GB (4095856640)
    Current Memory Usage: 19%
    Current DateTime:
    Loc: Sun Apr 2 00:45:38 2017
    UTC: Sun Apr 2 07:45:38 2017
    Application Data:
    Disk Avail: 895.2 GB (961289265152)
    Disk Avail: 895.2 GB (961289244672)
    Product successfully installed : Sci-Fi Warrior Guided Tour for DAZ Studio 4.8+
    --------------- Install Manager exited ------------------
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.7
    Locale: en_US
    Physical Memory:
    Virtual Memory:
    Avail: 3.8 GB (4096434176)
    Current Memory Usage: 36%
    Current DateTime:
    Loc: Fri Jun 9 21:01:02 2017
    UTC: Sat Jun 10 02:01:02 2017
    Application Data:
    Disk Avail: 877.2 GB (941910646784)
    Disk Avail: 877.2 GB (941910638592)
    Product successfully installed : Advanced Ambient Light
    +++++++++++++++ Install Manager Helper 1.1.0.74 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.7
    Locale: en_US
    Physical Memory:
    Virtual Memory:
    Avail: 3.7 GB (4044288000)
    Current DateTime:
    Loc: Tue Mar 20 13:00:19 2018
    UTC: Tue Mar 20 18:00:19 2018
    Application Data:
    Disk Total: 930.1 GB (998783025152)
    Disk Avail: 811.0 GB (870815809536)
    Disk Avail: 811.0 GB (870815797248)
    Executing file: C:/Program Files/DAZ 3D/DAZStudio4/unregister_file_ext.dzime
    Error loading script: C:/Program Files/DAZ 3D/DAZStudio4/unregister_file_ext.dzime
    Executing file: C:/Program Files/DAZ 3D/DAZStudio4/plugins/uninstall_dynamic_clothing_basic.dzime
    Error loading script: C:/Program Files/DAZ 3D/DAZStudio4/plugins/uninstall_dynamic_clothing_basic.dzime
    Could not extract file : C:/Program Files/DAZ 3D/DAZStudio4/boost_chrono-vc100-mt-1_50.dll
    Product installation failed : DAZ Studio 4.10 (Win 64-bit)
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.7
    Locale: en_US
    Physical Memory:
    Virtual Memory:
    Current Memory Usage: 17%
    Current DateTime:
    Loc: Tue Mar 20 13:05:40 2018
    UTC: Tue Mar 20 18:05:40 2018
    Application Data:
    Disk Avail: 810.7 GB (870558019584)
    Product successfully installed : DAZ Studio 4.10 (Win 64-bit)
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.7
    Locale: en_US
    Physical Memory:
    Virtual Memory:
    Avail: 3.7 GB (4043649024)
    Current Memory Usage: 43%
    Current DateTime:
    Loc: Wed May 16 22:10:19 2018
    UTC: Thu May 17 03:10:19 2018
    Application Data:
    Disk Avail: 781.5 GB (839225720832)
    Disk Avail: 781.5 GB (839225511936)
    Product successfully installed : GoZ for DAZ Studio 4.10+ (Win 64-bit)
    +++++++++++++++ Install Manager Helper 1.2.0.6 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 64
    Qt Version: 4.8.7
    Locale: en_US
    Running on Windows 10, Build 9200, No Service Pack Installed
    Physical Memory:
    Total: 31.9 GB (34332749824)
    Avail: 27.5 GB (29622083584)
    Virtual Memory:
    Total: 127.9 TB (140737488224256)
    Avail: 127.9 TB (140732990173184)
    Current Memory Usage: 13%
    Current DateTime:
    Loc: Fri Jun 14 00:13:36 2019
    UTC: Fri Jun 14 05:13:36 2019
    Application Data:
    Disk Avail: 560.2 GB (601513086976)
    Disk Avail: 560.2 GB (601512767488)
    Product successfully installed : DAZ Studio 4.11 (Win 64-bit)
    +++++++++++++++ Install Manager Helper 1.2.0.27 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 64
    Qt Version: 4.8.7
    Locale: en_US
    Physical Memory:
    Avail: 24.6 GB (26481397760)
    Virtual Memory:
    Avail: 127.9 TB (140732990070784)
    Current Memory Usage: 22%
    Current DateTime:
    Loc: Thu Sep 26 19:40:37 2019
    UTC: Fri Sep 27 00:40:37 2019
    Application Data:
    Disk Avail: 519.2 GB (557554352128)
    Starting CMS...
    Disk Avail: 519.2 GB (557554343936)
    Executed install script: C:/Program Files/DAZ 3D/DAZStudio4/unregister_file_ext.dzime
    Executed install script: C:/Program Files/DAZ 3D/DAZStudio4/plugins/uninstall_dynamic_clothing_basic.dzime
    Product successfully installed : DAZ Studio 4.12 (Win 64-bit)
    +++++++++++++++ Install Manager Helper 1.4.0.46 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 64
    Qt Version: 4.8.7
    Locale: en_US
    Physical Memory:
    Total: 31.9 GB (34303508480)
    Avail: 28.0 GB (30131671040)
    Virtual Memory:
    Avail: 127.9 TB (140733027647488)
    Current Memory Usage: 12%
    Current DateTime:
    Loc: Sun Jul 19 16:06:53 2020
    UTC: Sun Jul 19 21:06:53 2020
    Application Data:
    Disk Avail: 400.2 GB (429714866176)
    Starting CMS...
    Disk Avail: 400.2 GB (429714853888)
    Executing post install file: C:/Users/Drew/AppData/Local/Temp/DAZ3DInstallManager/InstallTemp/run_vc5_10_14_15_16_x64.bat
    Finished Process: C:/Users/Drew/AppData/Local/Temp/DAZ3DInstallManager/InstallTemp/run_vc5_10_14_15_16_x64.bat
    Install Successful: DAZ Studio 4.12 (Win 64-bit)
    Is that all of the log?  Open the log, select everything and delete it, and save and close the empty file.  Do the same for the helper log.  Then try another install and post the new logs.
  • Installing: 71015-1 : dForce Cimmerian Outfit for Genesis 8 Male(s)
    Could not extract file: C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/SadeMoonscape/CimmerianOutfit/4/boots/1001_BaseColor.jpg
    Install Failed: dForce Cimmerian Outfit for Genesis 8 Male(s)
    Installing: 2290-1 : Pteranodon
    Could not extract file: C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/SilverKey3d/Animals/PteranodonTexture1.jpg
    Install Failed: Pteranodon
    Installing: 14993-1 : Skull Rock DS
    Could not extract file: C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/AntFarm/SkullRock/AFSRchains_BHI.jpg
    Install Failed: Skull Rock DS
    Installing: 8010-1 : The Cistern
    Could not extract file: C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/!Orestes/cstrn/OGCT_clmn_bump.jpg
    Install Failed: The Cistern
    Install Queue Finished: 0 min 2.8 sec
    Can you go to the DIM downloads folder (C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads) and see if you can unzip the files manually (to a temporary location is fine)?  My guess is that the recent Windows update changed permissions on either the Downloads folder or on your My DAZ 3D Library folder so that DIM isn't being allowed to read/write to them.
  • Yeah I tried that. Did nothing.
    Do you mean you couldn't unzip it?
  • I can unzip  the files. I just can't get the install software to install them. I had to manually install everything which is a major pain and I don't want to go through that every time I purchase anything from Daz. I have tried everything....
    Can you go to C:/Users/Public/Documents/My DAZ 3D Library/Runtime, right-click on the Textures folder > Properties > Security, and post a screenshot?
  • No, I can't. apparently my pc wont let me do a screenshot and I can't upload a photo from my phone either. Everything was fine until yesterday. The only variable is Windows dumped a bunch of updates I didn't want or need onto my operating system and now everything is screwed.
  • Tell me what to look for on the C:/Users/Public/Documents/My DAZ 3D Library/Runtime, right-click on the Textures folder > Properties > Security
  • heres a snip
    567 x 765 - 46K
  • heres a snip2
    546 x 742 - 42K
    See if there's a User/Group named "Everyone", and what permissions it has.
  • No such user group.
    I'm not on Windows 10, so I don't know how User Groups are arranged.  Is their a group for Users?
  • yes. Default.migrated, Drew, and Public. The Daz folders are in public.
    Sorry, I mean in that Security tab
  • I don't see one.
  • MadbatMadbat Posts: 392
    edited July 2020
    I get the same error when DIM upgraded to 1.4 on win 7 x64. It reports an error unpacking DAZ3DDIM.exe. I was hoping to move a lot of my Daz stuff to a different drive tonight, but now I can't uninstall any of it apparently.
    Daz Connect will not work for me and I refuse to go near Daz Central.
    Post edited by Madbat on
    What security software do you use?
    Malware Bytes. I've never had a problem with it and DIM before. I was able to install an older version of DIM (1.1) and that installed fine. I can't download untill I upgrade however, and upgrading generates the unpacking error.
    I've seen that error with Malwarebytes running in real-time mode.  If it allowed the older version to install, see if the new installer works now.  If it doesn't, see if DAZ3DDIM.exe has an Owner listed in Properties > Security.  If it doesn't, Malwarebytes is messing with the permissions.  Turn off real-time mode in MBAM, reboot, and try it again.
    I just shut down Malwarebytes and DIM has installed and is downloading my content now. No owner is listed, just system, administrators and users. I'm listed as admin and user. This is after I shut down Malwarebytes.
    I hadn't considered Malwarebytes as the cause, I've always ran in real time mode with no issues installing DIM.
  • I don't have Malwarebytes on my PC.
  • Is it failing to download or failing to install?  What OS and security programs?
    install stops at 57%
