Octane v2.0 has been released
KrewKrew Posts: 25
Just a quick note for those using Octane, version 2.0 has been released. The Poser v2.0 plug-in has also been released. I just wanted to mention this because I didn't get an email announcing it and I just kind of stumbled across it today. The standalone update price is 99 euro and the plug-in update is free.
  • Midnight_storiesMidnight_stories Posts: 4,112
    Thanks downloading them now !!!
  • Coon RaCoon Ra Posts: 200
    Octane 2.0 displacement seems to be brilliant.
    And now it has hairs.
  • SimonJMSimonJM Posts: 6,108
    To temper that slightly ... from what I understand what you use to create the 'scene' for importing into Octane has to create the 'hair/fur', it's not something you can actually do within Octane, If I'm wrong on that I'd be happy!
    I got caught out by Octane 2 requiring a higher level of CUDA driver than I had (it requires a minimum of 6), but happily an update to the latest nVidia drivers fixed that, but for a moment I was seriously unhappy! ;)
    The Daz Studio plug-in is lagging a little behind the times, with the developer not quite there with the implemeting of the 1.5 release of Octane, so I suspect that the OcDS release tha uses Octane 2 will be quite some time off.
  • Subtropic PixelSubtropic Pixel Posts: 2,403
    Okay, but the REAL question is...will it run OPENCL on AMD graphic cards yet?
    This is the only thing holding me back from making a purchase.
    I use Modo. It was meant that Octan would need host's hair guides. The plug-in developer tells the hairs support in general is implemented into modo plug-in.
    As I understand Otoy comments Octane will never run OPENCL and never work on AMD graphic cards.
    So far as I know it still requires CUDA-compliant GPUs, which pretty much means nVidia only.
  • BendinggrassBendinggrass Posts: 1,391
    I could be wrong on this but I seem to remember reading that some Nvedia (spelling?) cards now use Open CL.
    I will look for that bit of info again.
    R
    R
    I believe some support OpenCL (so may be used by LuxRender), but Octane requires CUDA support.
    Yes, LuxRender supports OpenCL and so runs on AMD.
    I have AMD card and plan to add more. Octane needs to get with it. Write the code, code writers! ;-)
