Need help with bricks
mcpughmcpugh Posts: 105
This is probably a stupid newbie question but here goes:
I'm trying to create a brick wall by applying a texture jpeg to a flat primitive surface. The texture shows up nicely but when I stretch the wall to make it longer, the texture stretches with it. Then the bricks look like red dotted lines instead of bricks. How do I make it so the bricks don't stretch but do still cover the entire wall?
Thank you.
  • Richard HaseltineRichard Haseltine Posts: 111,609
    In the Surfaces pane increase the number of Horizontal tiles to get enough repeats of the texture to make the bricks brick-shaped. So if you stretch the wall out to 500% you'd want 5 horizontal tiles.
  • mcpughmcpugh Posts: 105
    AAAAAAAAH..... So THAT'S what vertical tiles and horizontal tiles means. Something so simple. I will never forget that now. Thank you!
