Question about RawArt’s Genesis 1 creatures
WonderlandWonderland Posts: 7,137
Wow, just discovering all of RawArt's earlier creatures! I was wondering if they all come with dials to mix with other characters or you have to load only as a full character. Thanks.
  • CybersoxCybersox Posts: 10,012
    Totally mixable as far as the morphs go, and they generally both convert well using GenX and can be split up with X-morphs... though obviously the geografts will only work with Genesis.  They also convert quite well to Iray using NGS Anagenesis 2 using the add-on shader for the grafts.  Of course, the greatest thing about the Genesis creatures is that you had male and female versions of each and could instantly build whole families.
    Thanks!
  • genejokegenejoke Posts: 131
    I stuck with genesis for ages because of the unisex thing, it's only in recent weeks I've moved to genesis 8 for new projects.
    I was V4 and Poser only until about mid-G3. I never liked Genesis 1 or 2 because the faces all looked very similar, unrealistic and had bad expressions compared to V4. I had some G1 toon characters but I'm just discovering the creatures and it does seem cool to be able to mix a lot although I do have creature morphs for all generations. It will be interesting to see if I can make them look decent in Iray though.
