Can't find clones
I'm trying to follow Coffee Art's tutorial for making a V4 clone for GF8, but the first step is hanging me up because I can't find G1's clones. I've loaded the G1 default and checked "show hidden notes", but no "hidden" parameter or clone parameter appeared. Is the Genesis V4 clone referring to something other than the one from this? If this is the clone I'm supposed to be using, how do I find my clone parameter?
702 x 388 - 162K
  • LeanaLeana Posts: 13,629
    The V4 clone is included in Genesis 1 base. What's included in the product you linked to is not a clone, ie a special type of morph used by autofit, it's a regular shape.
    Once you've selected "show hidden parameters" the dial for the V4 clone morph should be found among the Genesis morphs. I don't remember in which morph category it is but you will probably find it if you check directly under "actor".
  • D.A.ND.A.N Posts: 4
    in daz3d 4.23 de V4 clone not exist,,, how i can vave a v4 clone in my parameters tab
    5780 x 2095 - 751K
    It seems you've got some messed up assets installed, as those properties should be hidden from the user and have grayed out names.
    FIrst, you need to enble Show Hidden Properties from the Parameters pane menu(Pane menu/right click on Pane label>Parameters>Show Hidden Properties).
    Once that's  enabled the path is Hidden/Clones, with the label Victora4(Name is CloneVictoria4).
