Is there a way to teleport an object to another object?
Let's say I want an object like a Phone that's spawned into the scene at zero position...and instead of me manually dragging the phone across the scene to a Gen 8 character I want the phone to magically teleport to the G8's hand. Is there a way where I can specifically "teleport" the item to their hand and then I'll handle the rotations and whatever need be.
  • AscaniaAscania Posts: 1,855
    Use the Align tool.
  • macleanmaclean Posts: 2,438
    Parent it to the hand, then zero all Trans/Rot settings (Parameters> Menu> Zero>). Then position it.
  • DafaDafa Posts: 97
    Ascania said:
    Use the Align tool.
    How would I use the Align Tool to do what I want?
    Thanks, I'll try it out!
  • thd777thd777 Posts: 945
    edited July 2020
    Dafa said:
    Ascania said:
    Use the Align tool.
    Easy:
    1. Open the Align pane (from Windows -> panes)
    2. Set the X-, Y-, Z-Axis menus to "Align:Centers"
    3. Select your target node, for example the G8M hand. It should now be listed as "Keynode" in the Align pane
    4. Now use Ctrl-select to add the prop or props you want to move to the selection
    5. Click the Apply button and done!
    Ciao
    TD
    Post edited by thd777 on
    thd777 said:
    Easy:
    Ciao
    TD
    Cool thanks!
  • I have a different method but i'm not sure it will work all the time:
    1) Make sure you have your Gen 8 selected in Scene Tab, and Parameters tab (where X Y Z rotations etc are) is your active/selected tab
    2) Hit CTRL + C
    3) Now select the phone in scene tab
    4) Hit CTRL + V
    This should copy the X Y Z position and rotation of the Gen 8 to the Phone. You would have to align the phone manually to hand, but you don't have to drag it through all the scene :D
