Recommendations for Iray Server render farm?
Trying out Jack Tomalin's service but also wanted to see if there are other similar easy-to-use options out there in case there's a long queue or something.
Any recommendations?
Thanks very much!
  • SevrinSevrin Posts: 6,314
    Jack's is probably the best deal.  Others like nimbix charge by the hour, and the faster you need your render, the the higher the per-hour charge.
    Note: I have not used this service, but it doesn't seem terribly expensive to try, as long as you remember to log out when you're done.
