How to find new Non-DAZ content in DAZ Studio
Mosk the ScribeMosk the Scribe Posts: 904
I've been using the DIM for all my DAZ content isnstallations.
I also have a runtime called RobDAZ where I add other products from non-DAZ sources.
Just added a prop
Model includes the following files:
Runtime\Libraries\Props\!!!UweG\Barbed Wire.pp2
Runtime\Libraries\Props\!!!UweG\Barbed Wire.xmp
From top right of Content pane, I had DAZ scan known directories, but when I go under Poser Formats>Default?Unassigned>Props>
I don't see a listing for the Barbed wire pp2.
Do I need to do something else under the Daz Install Manager?
Anyone know where I should be able to find my new prop?
Thanks (note, I can directly import the object into Carrara which is where I needed it - but would like to know how to get my DAZ runtime working properly as well - and I'm still using Valentina as opposed to the new database since I do some work in Carrara as well)
Thanks
    If you are on a PC, you simply drop the Runtime folder onto the runtime folder you want to merge it with, the same as any other Poser content. There is a Runtime folder inside 'My DAZ 3D Library' which is there to hold Poser content. If you have never installed Poser content through DIM, it may not be there already, but if not, you can certainly create one yourself.
    The path to My DAZ 3D Library should be listed as BOT Poser and DAZ Studio Formats in your Content Directory Manager anyway.
    If you want to put it into your own Runtime folder (RobDAZ?) then simply drop the new runtime folder onto the one in RobDAZ, then make sure that it is listed as a Poser Formats folder in Edit > Preferences > Content Library > Content Directory Manager.
  • Mosk the ScribeMosk the Scribe Posts: 904
    Thanks - hadn't added path to my RobDAZ runtime yet. That fixed it.
