Open a recent Daz Studio 4.12.1 project in Daz Studio 2014 or 2016
Good morning, first of all I want to mention that I do not speak English, so I am using google translator to communicate with you.
As the title says, I want to open a recent Daz Studio project in a very old version of the software. More than anything because there is a free Addon that does not work in modern versions of the program (a bridge from Daz Studio to 3ds Max):
https://github.com/sebjf/dazmaxbridge
The most current versions of Daz Studio are closed when 3ds Max tries to send the file in Daz (I thought it could be the version of 3ds Max, but I tried one of the versions they recommend for the bridge, and the same thing happened with 3ds Max 2020, so the problem is Daz Studio).
I hope there is a way to do it.
Regards.
    What version are you trying to open the scene in?  Genesis 8 and the Genesis 3 Centaurs won't work fully in DS 4.8, but most other stuff should.
  • ChrisSerketChrisSerket Posts: 202
    It is a car bought in renderosity, so it is not a Genesis figure, but it has Iray materials.
    Iray materials should work mostly the same since 4.9.  Are you getting errors when you try to load the scene in an older DS?
    edited July 2020
    I still don't try it, because maybe it did the whole installation and in the end it didn't work.
    So I preferred to ask.
    Now I will try.
    Post edited by ChrisSerket on
  • SixDsSixDs Posts: 2,384
    Are you trying to install a version of DAZ Studio that is version 4.5 or later on a machine that already has a later version of DAZ Studio installed? If that is so, you may be having problems due to a conflict that arises when doing that - you can install a general release and a beta relese on the same machine without conflicts, but not more than one general release.
