Tesla's the meeting room CTRL + L not working
The Meeting room is visible in IRay, but not texture shaded (in the viewport) I tried ctrl + L, I updated my GPU's drivers...but the scene is pitch black unless I'm in IRay.  Any suggestions?
  • GordigGordig Posts: 10,819
    Are there actually scene lights, or are they all emissives? How is your camera and/or viewport headlamp set?
  • comixfanacomixfana Posts: 278
    I forgot to say: I'm a noob!  What's the difference between scene lights and emissives? I presume it's emissives
  • SevrinSevrin Posts: 6,314
    Scene lights are Spotlights, Point Lights, Distance Lights, etc.
    Never mind, I used a light set from a different set and thatb seemed to work!
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Did you ttrty Window>Preview Lights (which, by the way, means "preview the lights in the scene" and is on by default - the first tiem you hit the command you turn it off and should isntead get a headlamp that illuminates the scene). Which preview mode were you using? The command has no effect in Iray preview mode.
