Crash/Possible to disable Auto Fit?
davidb408davidb408 Posts: 0
I am trying to get the Monk Robes to work with the Genesis 2 figure. If I load Genesis 2 Male, load the Monk Robes and use Fit To, it asks what figure it was designed for. If I tell it Michael 4, the application crashes.
I also have the M4 to Genesis 2 morph so that M4 clothing should work with G2. When I load the Monk Robes, the appear slightly larger than the Genesis figure (sized for M4), and if I use the M4 for G2 morph, it resizes the G2 figure to the M4 size and they fit perfectly. However when I use Fit To and accept the defaults, the robes resize larger. Is there a way to use Fit To without letting Auto Fit do it's thing?
  • srieschsriesch Posts: 4,243
    In the AutoFit window, when you are prompted which figure the clothing is for and what type of clothing it is, you can just press the Cancel button so AutoFit doesn't happen. Of course, then the clothing isn't fit to the figure, so this is of limited use, although in certain limited circumstances one could still use some clothing articles that way.
