Problem with all Victoria 4.2 morphs / INJ and Dials / POSER 2014 (MAC)
Hey guys.
I just bought Victoria 4.2 with all morphs, ++, Elite, Muscles, Stephanie 4 etc...
I made some screenshots because its crazy and I dont understand whats the problem.
My poser 2014 is fully updated, The runtimes are OK, etc...
So first I load Victoria 4.2, Check the dials.
SCREENSHOT 01
Then I load Morphs ++ and nothinh happens in dials, except in the Base section, it says Palmsize. When turn it nothing happens too.
SCREENSHOT 02
Then I try with muscle morphs and its the same problem, nothing happens, except in the base section "Wirey" ....
SCREENSHOT 03
I really need your help guys, because I dont understand whats wrong with the morphs.
Thank you !
Kse
1920 x 1200 - 340K
1920 x 1200 - 342K
1920 x 1200 - 307K
    The latest version of Poser that I have is Poser 8, and it works OK with it, see screenshot below.
    I don't know what the problem can be, does Poser have a log file that you can look at, it may shed some light on the matter
    1152 x 864 - 493K
  • edited June 2014
    Ok thanks. I check the log and I'll be back.
    Post edited by cedric_eab4474598 on
  • edited December 1969
    Woaw.... I just have this in the log tab :
    17:46:42 - Application commands: Add figure(s) from library
    17:47:40 - Application commands: Load library pose
    Normal ?
    Thanks
    Ok I never tried to launch "DzCreateExPFiles-V4.command".... it works for M4 and for V4V3. But When I try to launch the "V4" the terminal says permission denied. I checked the authorisations for this file and its the same as M4 and V4V3.... Really strange...
    ALLELUIAAAAAA. It works. I just duplicate the M4 file, change with copy and paste what was in the V4 file. Launch it and it works. I just checked in Poser and all th emorphs work perfectly !!!! FANTASTIC :)
  • TotteTotte Posts: 15,110
    Looks like it is solved or?
    I posted about the execution bit missing in the application that is executed by the scripts (the scripts just tells it what to do), and the bug is in the DAZ Bugtracker.
    Thank you very much Totte ! Yes its solved !!! :)
