Change Rotation Order AFTER Figure Setup
mirjagirlmirjagirl Posts: 85
edited July 2020 in The Commons
Is there a way to change the rotation order AFTER the figure has been setup?
BACKGROUND
Built in Blender on the Z axis (floor).
When I did the rotation to set to my model, I was so used to my test rotation that, well now:
Side to Side is now Bend
Twist is now Side to Side
and Bend is now Twist.
Ummmm, help?
Is there a way to fix this without redoing the figure setup or going joint by joint?
Post edited by mirjagirl on
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Its at the top of the Tool Settings pane with the Joint Editor active.
  • mirjagirlmirjagirl Posts: 85
    So, joint by joint is the only fix for this?
    As far as I can see, barring a script - it's also in the Joint Editor right-cick menu, but even with multiple bones selected it affects only the primary selection.
    (Sad Face)
    Ok.  Truly a Never Hurts to Ask situation.
    Thank you.
