"Clamped" DzIntSlider isn't really clamped
I've got the following code:
var sld = new DzIntSlider( wDlg );sld.label = "On position";sld.min = 1;sld.max = 2;sld.value = 1;sld.clamped = true;sld.labelVisible = true;wDlg.addWidget(sld);
When I run the script, the slider starts with a value of 1 and goes up to 2, but 0 is still an option. How is that possible if the min is set to 1? Shouldn't the min be the lowest possible setting?
  • GordigGordig Posts: 10,821
    I just tried an enumslider and a floatslider, just to see how they worked. I could bypass this issue by just using an enumslider, but I'm still curious about the answer, because the floatslider didn't fully respect that clamped minimum value either.
  • Cayman StudiosCayman Studios Posts: 1,145
    If you set the min after you've set the max the minimum value is respected.  Don't ask me why!
    How frustratingly arbitrary. Thank you.
  • fixmypcmikefixmypcmike Posts: 19,737
    If you set a minimum which is illogical (not less than the maximum), DS assumes you made a mistake.  Set the maximum first so that the minimum makes sense.
  • Richard HaseltineRichard Haseltine Posts: 111,875
    And if you ever want a negative maximum set the minimum first, so that there's room.
