Help with Clothing Cleavage Modifier
chrisvikachrisvika Posts: 0
Does anyone know if this works with Victoria 4.2? If so, how do you get it to work?
Thanks in advance,
Christian
  • fixmypcmikefixmypcmike Posts: 19,742
    No, it is a set of morphs for the Genesis mesh and won't work with V4.
  • chrisvikachrisvika Posts: 0
    Thanks for the response. I was confused because the description said:
    "Forty nine individually hand-crafted breast smoothing morphs for ALL the major Genesis shapes (Basic/Reby Sky/Stephanie 4/Victoria4/Victoria5/Victoria five Super Model/Voluptuous/Aiko4/Girl4)"
    Guess I'll have to return it, I rarely use the Genesis figure. Do you know if there is a product that has a similar effect for V4?
  • IceEmpressIceEmpress Posts: 639
    So does that mean that this would be good when using second skins, since they're Genesis morphs?
    The way that these work is that there are a pair of opposite morphs that cancel each other out, with only one set to autofollow. Do both morphs are applied to Genesis, cancelling each other out, but clothing only follows one of them. That wouldn't work for second skins directly, although you could probably turn off the second morph of the pair so it wouldn't cancel out.
