Dforce hair invisible in iray
I just purchased the dforce dark match hair, and it's completely invisible. Only the scalp element appears in the viewport. Without a proper preview how am I supposed to properly pose or set it up? There is an nvidia preview prop in clumping options (why there?) but it does absolutely nothing, nada nilch.
And when I try to render a scene with it Daz3d instantly uses up all available memory that's insane for a single hair prop.
Most useless product ever.
Post edited by mumia76 on
You may need to increase the segments, as well as turn on the preview hairs. The precise settings for the Iray previiew may also be a factor (Draw Settings pane).
Hi Mumia. Please make sure you do not have the mesh grabber tool or the geometry editor tool selected.
If you are using the NVIDIA renderer, in your render window it looks like a little cube: You will need to select the hair object in the scene. It is parented to the hair cap. Then you can click on the NVIDIA ON option.
Also, there is lots of helpful information in these forum threads: https://www.daz3d.com/forums/discussion/413861/released-dforce-sea-salt-commercial/p1
https://www.daz3d.com/forums/discussion/392566/released-dforce-soft-curls-commercial/p1
